Author Topic: Render - comfortable rings  (Read 496 times)
Offline TCP
« on: August 10, 2022, 02:01:15 pm »
Hello everybody.
When I render comfortable rings (internally rounded), the image does not show this curvature, they look flat on the inside. Any tips on how to make the image show that there is a curve inside the jewel?
Offline INNEO_MWo
  • Total likes: 85
Re: Render - comfortable rings
« Reply #1 on: August 11, 2022, 08:37:16 am »
Does rendering in NURBS mode may help here?
Offline TCP
« Reply #2 on: August 14, 2022, 04:38:07 pm »
Hello. Yes, I tried with NURBS mode and still the inside looks flat.
Offline DriesV
  • Administrator
  • Total likes: 83
« Reply #3 on: August 17, 2022, 06:59:09 am »
Hi
With highly reflective materials, such as metals, it is very hard to visually define the shape of objects. There is a good reason why diffuse clay models are often used for lighting and shape studies, for example in the automotive industry :)
To help accentuate the curvature of the ring's inner surface you could perhaps apply a directional texture, like a subtle brushed texture with cylindrical mapping.
I don't think you will have much success with a perfectly polished surface...
Attached are renderings of two versions of the same ring: with a polished and brushed inner surface.
« Last Edit: August 17, 2022, 07:00:56 am by DriesV »
Offline TCP
« Reply #4 on: August 19, 2022, 11:03:26 am »
You are absolutely right, thank you. Maybe if in the next versions of KS the reflection of one object was not projected on the other, it would help.
