keyshot 3 plugin for rhino 1.0 error loading ?
Started by imu2011b, December 17, 2011, 02:13:13 AM
imu2011b
after i open rhinogold and rhinoceros too,,, in loading windows say it is error loading,,,
cant be load,,, my keyshot 3.082 version
what the problem is ?
is the plugin only support for keyshot 3.09 only ?
thanks
This is independent of the version of KeyShot 3 that you are running.
Are you getting the error when you are using the plugin?
imu2011b
after i install the plugin,,, and i open rhino4sr9 ,,, it shows windows is loading keyshot3,,, then says error loading keyshot 3
nautilus
"Unable to load keyshot3_rhino_plugin.dll plug-in:could not open the plug-in file."
Tried to load a copy of the firle from the Rhino plugin folder already. same error
In my case I do not have RhinoGold, just fresh install of Keyshot 3 64bit & Rhino 4s
jhkim
Did you fix this issue?? Then pls let me know how to do that.
I have exactly the same problem here with KeyShot 3 and Rhino 3D 4.0.
JH
You need to download and install this:
Microsoft Visual C++ 2010 Redistributable Package (x64)
http://www.microsoft.com/download/en/confirmation.aspx?id=14632
Microsoft Visual C++ 2010 Redistributable Package (x86)
http://www.microsoft.com/download/en/confirmation.aspx?id=5555
jhkim
Thanks Thomas, but still I got the same error even after install the Microsoft stuff.
Is there anything else I have to do??
It seems that the plugin dll is not registered correctly, so I tried to register manually, but failed.
And there is no KeyShot related file in the Plugin folder in Rhino 3D Application folder.
So I could not understand what causes this problem.
JH
