KS3 Render options
Started by caden2010, January 04, 2012, 01:33:16 PM
caden2010
Hi, I am having problems rendering in KS3. As soon as I press 'Render' it comes back 100% and renders a very small portion of the image.
I had assumed that 'Region render' was activated as I have been using this on KS2. For info I have both a KS3 Pro and Animation.
I have added the render BRG_2.19.tif for reference although there's not much to see!
On checking my render options I seem to be missing 'Queue and Region'. I have added a snapshot of my Render Options window.
Can you please explain what's wrong. I am running Windows 7 64 and KS 3.0.93 (was the same issue in 3.0.90)
Zander85
Your probably going to need to uninstall Keyshot and remove old versions of it and re-install the newest version. good luck
It looks like that you are running the regular KeyShot version and not Pro with Animation.
caden2010
Thanks for the reply Thomas.
Looks like there has been a mix up when changing from KeyShot 2 to KeyShot 3.
I will contact the licensing department to obtain the correct license.
caden2010
Just for info. I already have the correct licenses but it was not correctly configured when I upgraded from KeyShot 2 to 3.
All OK now apart from de-activate and re-acrivate on another machine.
This is being looked into though so I am confident that all will be OK soon.
Thanks to both for the advice.
