Undo/redo function in annimation
Started by vmohoney, January 26, 2012, 01:40:04 PM
vmohoney
Animation undo/redo:
I wish i had back all the time spent (lost) when I try something new and it did not work as expected.  An undo and redo are equally important when this happens.  Rhino has this functionality where you can set the number of undo and redos and a setting for memory to allocate for this.
Grouping for animations a must
Highlighting to be more pronounced in the scene tree when selecting parts in the realtime window, its very difficult to see.
You can undo animations. We are looking at redo and the other things you mentioned.
I'd sure like to see Un-do work as a full "step back" feature, in sequence.  For some reason, it defaults to the original or hero view first, then starts the un-do process.  Ideally, ctrl+Z to undo everything in sequence, and perhaps ctrl+X or something reserved just for material undos, which is our primary use.  And please, a reset on all material tabs!
Yes - we just added this list of things to do.
