Author Topic: KS3 crashed when importing KS2 bips or packed files  (Read 3161 times)
Offline Berzerkdesign
« on: February 09, 2012, 12:36:34 pm »
Hello all,
I am totally new to this forum, so first of all I am glad to own KS3 now.
But I am suffering some Problems. I was using the demo of KS2 a few months ago. There I created some scenes which I saved as BIP and KPS. Some of them can be opened in KS3, while some of them cause a crash of KS3.
Is there any important thing I have to look for while opening KS2 files in KS3?
Thanks in advance!
Offline KeyShot
Re: KS3 crashed when importing KS2 bips or packed files
« Reply #1 on: February 09, 2012, 09:59:48 pm »
We did fix an issue in KeyShot 3.1 where a KeyShot 2 file was using the general material. We will release KeyShot 3.1 soon. If this is not the issue then please share the file with support and we will take a look at it.
« Reply #2 on: February 09, 2012, 11:02:32 pm »
Thank you!
Indeed this seems to be the reason, both models which caused the crash have general material for tga texture with alpha channel.
I tried a model without general and that worked.
Some crashes still occured while changing materials, but thats minor. I will keep an eye on that
So now I am waiting for the patch :-)
« Reply #3 on: February 10, 2012, 04:00:20 am »
I tried to remove the General material from the parts where it was used, then I packed the KPS again, but the import in KS3 does fail again.
Do I do something wrong?
Or is just not that simple to avoid that problem until you fixed it in the new version?
EDIT: Problem solved! I forgot one part which still had general material. Imported now perfekt without issues. Waiting now for 3.1 :)
Thread can be closed. Thanks for your help
« Last Edit: February 13, 2012, 03:49:58 am by Berzerkdesign »
