Author Topic: A problem that I not understand...  (Read 5377 times)
Offline rafita
« on: February 25, 2012, 02:03:26 pm »
Anyone can help me please?
Thank you
R
Offline Pasu
Re: A problem that I not understand...
« Reply #1 on: March 05, 2012, 05:21:55 pm »
I am not an expert, but I think that .dwg is only a 2d drawing file - you'll need a different file type for keyshot to open.  Hence your error 'no 3D data' - dwg is just a line drawing.
Can you re-export your file from your 3d program as something else?  Iges, stp (step)?  Keyshot also opens many 3d programs native file formats, for example rhino and solidworks.
Offline rafita
« Reply #2 on: March 27, 2012, 07:35:17 am »
thank u mate. I imported my 3Dmodel.dwg in max and then exported it in 3ds file. that's it
Offline KeyShot
« Reply #3 on: March 27, 2012, 07:02:33 pm »
KeyShot can import .dwg files natively. If you can share your file with support we can take a look at it.
Offline rafita
« Reply #4 on: March 28, 2012, 03:17:31 am »
I don't belive that because I work just with AutoCAD and only in two time I had this problem. I don't know the problem (and I don't know what  you mean for .dwg file natively) but I think is a problem of solid connections.... fittings 3D basically.
  • Guest
« Reply #5 on: March 28, 2012, 08:59:50 am »
Can you please share the file so we can take a look?
Offline rafita
« Reply #6 on: March 28, 2012, 09:53:54 am »
I attached 3 dwg file. The real difference is between bracelet2 and bracelet3.
The bracelet2 don't work. The third work, but I try to cut the initial part of bracelet. So, I think that the problem is the different way of modeling in AutoCAD, or the different command... maybe.
Thank you for your attention.
PS: I can't post all the bracelet with all the parts because the design is not protected.
