Cactus
Started by Esben Oxholm, February 27, 2012, 09:31:27 AM
Esben Oxholm
Did this yesterday for a speed challenge at the Danish 3d-forum 3dmaxer.dk. The subject was things that poke and there was a total time limit of 3 hours.
My time use:
Modelling (3ds max): 40m
Texture (photoshop/keyshot): 1h
Render (keyshot): 1h
Post (photoshop): 10m
TOTAL: 2h 50m
I've got some problems with the shadow around the pots. It's not very smooth. The pots are "snapped to ground". If I lower them, they will be beneath ground plane, and if I raise them, they float. The render is a 1hour realtime render. Is it possible to fix it?
Best regards
Esben :)
It looks like your pots are slightly tilted. You may have to move them manually. And then increase the shadow quality if needed.
Esben Oxholm
The camera was tilted, but not the pots. I think it's the shadow that makes it look like it.
I have increased shadow quality to max, 5, and it helped, although it's still not perfect.
Josh3D
The textures and color is great. Good call on the shadow quality. I think an outdoor environment would really make this look brilliant.
Change the cola length to 75 - 100. This will help, too.
Esben Oxholm
@Thomas: I'm not sure where to find the cola length? A look in the manual and a google search didn't help me :/
cola - lol - damn autocorrection - I meant focal.
PhilippeV8
Esben Oxholm
Haha, I also thought that cola length didn't make any sense  ;D
I see that changing the focal length helps, but then I loose some of the depth perception. I like the view more wide angled.
How come the shadow quality is depended on focal length?
That shouldn't be the case.
