Author Topic: Same animation for 100 objects  (Read 2465 times)
Offline andreb
« on: March 14, 2012, 03:07:04 am »
Hi everybody,
I started to work with keyshot a few days ago and wanted to know what is the best procedure to animate diamonds rings.
I need to do the same animation with the same lighting for more than 100 rings.
I know I can save and copy animation in the same window but...
Should I import the 100 rings in the same environment?
I guess some of you already did this kind of work.
Any advice would be really appreciated ;)
Andr
Offline KeyShot
Re: Same animation for 100 objects
« Reply #1 on: March 15, 2012, 01:15:21 am »
If you only want to show one ring at a time then I would recommend importing one ring at a time. Copy the animation. Delete the previous ring. Add to queue (if you are on pro). And render all the rings when done.
Offline andreb
« Reply #2 on: March 15, 2012, 07:10:21 am »
Thanks,
This is what I wanted to do, it sounds logical.
Andre.
