Sea reflection
Started by dimr, March 16, 2012, 06:53:51 AM
dimr
it took  a lot of time  to get the reflection of "the sun and clouds , the sea surface " but i reached this point. thanks to keyshot developers
PhilippeV8
TIP: make your water-part a circle instead of a square ... it'll make the horizon blend better !
The reflection of your boat is awesome ... water is kinda calm though to be shot at sea ...
Something also makes it look like a scale model ... not sure what though ... maybe if you add some people stuff in post (a captain, some towels on the deck, ...)  Ah and deff. try to add boat wake behind it ... maybe you could do that with a transparent label ??
Also tilt the boat away from the wind/camera.
dimr
Dear Philippe ,
thanks for your advices ,
I will consider and try to imrove the models
I tried cirlce it was quiet different than what i expected to get  , i will try to do another render with a circle sea surface .
and for the wake , you are right ! i will try to get an example from a real  wake picture and make it a transaparent label ..
of course the vessel must be a bit tilted
i need to find a good sea surface bump too . in some parts it looks like broken ice .
trice1
