Wish I could spin my wheels..
Started by eze49, March 21, 2012, 12:03:40 AM
eze49
Wish there was a way to add motion blur to a still render.
especially rotational, and set the speed, to say the wheel of a car.
galnor
I have the same problem. This function is missing:-(
Despot
Well, in all the 3D packages I've ever used over 20 years - I've never heard of one that allows you to add Motion Blur to a static object...
PhilippeV8
*cough* ... 3DSmax ... *cough*
It's done by animating, then it'll render up several animation frames, then blur them together.
Despot
I know how motion blur is  achieved Phillipe ;) I meant applying it without animating the object first...
Which is what I thought they meant...
J
PhilippeV8
Well there IS the animation option in KS, so even without activating the entire animation setup in KS, it could probably be done ...
Select an object (like a weel), set it's rotation axis correctly, then set how fast it should "blur" rotate.  Then have KS render out a couple of renders and blur-merge them together after the proces is done.  I'm sure it can be done by KS.  Not in 1 go, but the whole render step phase could be done automaticly.
