Author Topic: Video Problems  (Read 5044 times)
Offline edan8
Video Problems
« on: May 24, 2010, 11:16:10 pm »
Hello.
I am an ex-hypershot user and I just started with Keyshot and I can not seem to get the scroll wheel to work when I want to zoom in/out.
So far I have bought 2 different mice as I originally thought this was the problem. It still will not zoom correctly.
The only way I can use the wheel is to very quickly rotate it.  This will work about 50% of the time.  The problem when it does work is that I do not have control over how the model is positioned as it will zoom out of the frame.
I also have a problem of sometimes when I turn the model, only a small portion of the screen appears to move.  This is usually a square section about one-eight of the screen.  The only thing I can do when this happens is to wait for about 10-15 seconds for the rest of it to “catch up” or minimize and maximize the screen.
This is a brand new system.  No other problem with video or performance on any other programs.
Any ideas as to how I may correct these issues please?
Thank you.
AMD quad core
Win 7
Nvidia GeForce GTS 250, 1 gig RAM
  • Guest
Re: Video Problems
« Reply #1 on: May 25, 2010, 01:04:38 pm »
You know that "zoom in and out" changes the focal length? Does panning of the camera work when you press ALT + MMB? It is a mouse setting most likely, nothing else.
The other problem is a general graphics issue on Vista / 7. Has nothing to do with KeyShot in particular - other programs like SolidWorks suffer from this as well. The quickest remedy is a right click into the realtime window.
Thomas
Offline edan8
Re: Video Problems
« Reply #2 on: May 25, 2010, 02:21:52 pm »
Thank you for your answer on the graphics issue with Vista/7.  It’s good to know that there is nothing wrong with my system.
I am embarrassed to state this but I am now confused as to what is the correct procedure for zooming in/out.
My understanding was that the ALT+ mouse wheel was the correct procedure for this.
Is this correct?
I am trying to learn the correct terms but it sound like I don’t fully understand what camera focal length means.  I will be looking this up again as it appears I may not fully understand.
The ALT+MMB only work 20-50% of the time.  I have set up a different button combination to pan.  My mouse has sideways scrolling. Could this be the problem?
Thank you again for your reply.
  • Guest
Re: Video Problems
« Reply #3 on: May 25, 2010, 02:29:04 pm »
Zooming in KeyShot means "changing the focal length".
Moving the camera - that is zooming in the CAD system - is done by alt + RMB. That's what you want most of the time, and then change your perspective by changing the focal length.
Sounds like the sideways scrolling is screwing things up. Definitely a mouse issue, not a software issue.
Thomas
Offline edan8
Re: Video Problems
« Reply #4 on: May 25, 2010, 06:26:34 pm »
I am a little slow sometimes but I understand my mistakes now.
Thanks again for you patients.
  • Guest
Re: Video Problems
« Reply #5 on: May 25, 2010, 06:27:43 pm »
No worries - that's why we are so we can help!
