water pump render
Started by tsunami, May 17, 2012, 02:16:04 AM
tsunami
Here some renders about water pump..
tsunami
are those really bad renders?...
Josh3D
He Tsunami! Not at all. The Texture is a bit extreme in some areas. I'd actually try a water pump with out it or some very, very subtle texture. Since water pump are cast, you may want to go for a more cast texture. This looks more stamped. Unless you want a chrome sort of look. Do you? When in doubt, Google Images :)
Hope this helps!
Josh
tsunami
Quote from: josh3d on May 18, 2012, 11:44:25 AM
Hope this helps!
Josh
Thanks Josh....hm yes in some areas are too much extreme,..however keyshot is pure POWER ;D
Josh3D
voxelman
Right, I'm addicted and thank the rendering gods so is my boss!
Nice work Tsunami.
