Author Topic: Rendering - Tomek Jarosz - Swatch Chrono  (Read 12402 times)
Offline homolongus
« on: May 20, 2012, 04:03:25 am »
Hi all,
at the beginning I would like to thank the guys from KeyShot for their superb piece of software. Ease and speed while generating stunning visualizations can not be compared to anything else.
That's why participation in this contest is a pure pleasure  :D
The only thing I wish for is a little bit faster computer - at the moment I am working on a laptop - to be able to use the full power of KeyShot  ;)
For the competition I decided to use my own watch. I was sure that KeyShot perfectly can handle translucent and transparent plastic it is made of. It was not necessary, but the final rendering I decided to gently finish up in the PS (color correction + vignetting + bokeh).
I hope you will like it...  :P
  • Guest
Re: Rendering - Tomek Jarosz - Swatch Chrono
« Reply #1 on: May 20, 2012, 07:14:04 am »
Very impressive. Well done.
Offline homolongus
« Reply #2 on: May 20, 2012, 07:21:59 am »
Thank You  :)
It's easy with KeyShot  ;)
Here is another try - made with just one single light...
Offline abedsabeh
« Reply #3 on: May 20, 2012, 07:47:10 am »
Nice work, well done!!!
Offline CAClark
« Reply #4 on: May 20, 2012, 12:41:12 pm »
Maybe the anchor points for the strap look a little too clear, but the render still looks lovely!
Cheers!
Offline PhilippeV8
« Reply #5 on: May 21, 2012, 02:17:48 am »
I like the blue one !  Perfect !
For the red one, CA makes a valid remark .. absolutely.
Offline homolongus
« Reply #6 on: May 22, 2012, 02:22:38 am »
Thanks guys, you're absolutely right - I changed the primary material unnecessarily in the red version  :P
Anyway..
this time I decided to do something like a poster - two lights set at the top and bottom to correspond with background, which adds a little "holiness" to the topic..  ;)
Hope You'll like it  :D
Offline PhilippeV8
« Reply #7 on: May 22, 2012, 02:25:53 am »
The botom most part looks less photo-real now ... the rest = stunning.
Orange and blue ? ... this could be a movie poster  ;)
Offline homolongus
« Reply #8 on: May 22, 2012, 02:51:26 am »
Thank You Philippe  :)
As usual you're right. Most tests and adjustments I made exactly to the lower light. Finally I decided to flatten the lower part so that the upper came to the fore. The second option was to darken the bottom part of the watch but I was less satisfied with the end result.
Could be better - I know - but it is all just for fun isn't it?...  ;)
Offline homolongus
« Reply #9 on: May 31, 2012, 10:19:40 am »
Wow! Honorable Mention!?! Yeah!!!   :D
Thank You guys for the great contest! Superb software! Lots of excellent works. See you next time ;D
Offline feelstuff
« Reply #10 on: June 08, 2012, 12:24:17 am »
awsome works ! would anyone share something about how to add light in keyshot ? Thanks a lot ```
Offline homolongus
« Reply #11 on: June 18, 2012, 05:04:17 am »
Sure! There are at least two ways. First, you can insert additional object (plane, sphere, etc) and give it "light" material.  In the new version of Keyshot you can also edit the HDRI map and instantly add a whole new light source.  :)
Offline EGON
« Reply #12 on: June 18, 2012, 10:42:29 am »
Really nice! The strap material in the second one............so Swatch like. Amazing.
