HP Elitebook 8560w - Intel i7-2620M 14.0 FPS
Started by dblaveino, May 22, 2012, 09:41:52 AM
dblaveino
HP Elitebook 8560w
Windows 7 - 64 bit
Intel i7-2620M @ 2.70 GHz
14.0 FPS
It starts out around 120 FPS then really slows right down and hovers around 14 FPS...
Considering the specs of your CPU I'm guessing your score should be higher.
No dust bunnies inside your cooling system, blocking airflow?
I had a similar thing going on with my notebook. Cleaning it out doubled my score (3.5 to 7, yay!  :D).
Try running CPU-Z or any other tool that can monitor CPU clocks, alongside KS bench. On my notebook -before cleaning- I noticed a drop from 2.2GHz (base clock) to 1GHz due to overheating. KS bench score dropped significantly from then on.
greetings,
Seghier
i have the same laptop
priority of keyshot in task manager is under normal as default
change it to normal
fps will be 20
voxelman
Try rebooting and make sure Keyshot is the only application you have running. My Sony is doing 19.5 with only a 1.6 GHz clock. I'd expect to see something like 25-30 from your Elitebook.
