Author Topic: Frame rate  (Read 7886 times)
Offline Simon N
Frame rate
« on: May 23, 2012, 08:51:30 am »
Hi guys. Is there any way to adjust the frame rate when rendering out an animation?
Also, I have found that when adding some materials/labels to my model it has affected how it animates. The only thing I can think could be causing it is when I have 'unlinked' a material to apply labels etc to different surfaces. Is this a glitch or am I doing something wrong? I had a model animated exactly how I wanted it, then after changing some materials etc the end of the animation went haywire!
Thanks for your help.
  • Guest
Re: Frame rate
« Reply #1 on: May 23, 2012, 09:07:08 am »
click on the the "gears" in the animation time line to change the frame rate.
We would need a more specific example to understand what you are observing as far as animations and materials go.
Offline Simon N
Re: Frame rate
« Reply #2 on: May 23, 2012, 09:28:19 am »
Thanks Thomas!
I am trying to speed up the rendering time of a 30 second animation I have, it currently is rendering 756 frames and I estimate it's going to take 12+ hours to render. Is there a minimum frames/sec that you would advise not to go below? I need to render 3 of the same animation with different graphics applied, so I would like to cut the rendering time a bit whilst not compromising on the quality.
  • Guest
Re: Frame rate
« Reply #3 on: May 23, 2012, 12:01:14 pm »
Depends on what you are rendering for. If it is for web, then you can get away with 12 fps.
