Labels flickering in animation
Started by Simon N, May 24, 2012, 02:14:52 AM
Simon N
Hi. Just rendered an animation (a printed box) and found that on 1 of the faces the label appears to flicker on and off in some of the frames. Is there anything I can do about this? In truth it is not actually flickering on and off, but changing to a different part of the label and back again (it only lasts for 1 frame at a time).
Any advice on this would be much appreciated!
Is this with a simple turntable animation in 3.2?
Bruno F
Did you use Default, Background, or Network Rendering?
Simon N
Quote from: Thomas Teger on May 24, 2012, 07:07:19 AM
There is a turntable part that flickers, although there are other translations where the flicker also occurs. I rendered out the individual frames and saw that occasionally a frame would have the altered label, which causes the flicker in the animation...
Simon N
Quote from: Bruno F on May 24, 2012, 04:28:14 PM
I used just the default rendering.
voxelman
I think I'm seeing a related type of artifact. See the attached animation. Turntable default rendering.
This is strange - did you keep the frames? If so, are you seeing this in the individual frames? What version of KeyShot are you using.
voxelman
I didn't save the frames but I will rerun the animation so that they are. Keyshot 3.2.32 64-bit.
voxelman
Yes, I see this in the frames. I'm wondering if this could be cleared up with some changes to the rendering parameters but I don't have time to fiddle with it right now.
