Radiator casing
Started by DriesV, June 01, 2012, 02:51:56 AM
Here is a render of a very quickly set up scene with a low surface temperature radiator.
What you see is effectively the backside of the radiator  ;).
greetings,
fario
bravo!
your whites are very successful.
Antoine
White is a VERY plain paint though  ;D.
But I agree that it works very well for this particular scene.
greetings,
PhilippeV8
Does this work on these as well ?
tsunami
Yes the white is working good!!..i think the left top black plastic material is not good as white material..it's seem not realist..
This is mine opinion..... ;)
Regards
#5
Quote from: PhilippeV8 on June 01, 2012, 04:13:03 AM
No, the case is designed to hold steel panel radiators only.
You are running these cast iron radiators on a high temperature heating system? Little kids jumping arund and touching things?  ;D
greetings,
#6
Quote from: tsunami on June 01, 2012, 04:21:29 AM
Regards
You're right!
I think this rendering much better resembles the plastic caps in reality.
The plastic has a very rough texture to it.
The 2nd rendering is the termostatic head that fits underneath the plastic caps
greetings,
