KS3.2.32 Problem- Labels turned off, materials "black"
Started by Imz, June 01, 2012, 02:46:03 PM
Imz
Hi Guys,
I'm having trouble opening past projects- I could really use some wisdom.
When I open any of my projects (which have been working fine) all decals/labels are off, label positions in some cases are lost, and many of the materials are either solid black, or solid white... If I re-assign a correct material, of course I loose all my decals.
Is there a fix? Or a way to uninstall the update and revert to the last version of KS3?
Below is a snapshot of what I'm seeing; not quite what I intended...
Hi Imz,
Strange.. Have you moved any folders around lately that would contain these labels?
If not, I sent you the 3.1 links. Try it out and let us know if it makes any difference.
Chad
