Fabric lamp shade
Started by solodesign, June 11, 2012, 06:47:20 AM
solodesign
I' ve seen there is a similar topic here (http://keyshot.com/forum/index.php/topic,1074.msg4153.html#msg4153) but if I try to reply it suggest opening a new one.
How do I reach similar results with newer versions of Keyshot?
Please, what I need is the most detailed and step-by-step description of the process you can give.
Don' t assume anything for given because maybe what' s natural to you is not natural to me.
Thank you,
solodesign
I am trying to render using traslucent material and applying a gray map to opacity to give transparency.
You can see the result in the attached image.
I' m not satisfied of the result.
Overmore I can' t understand why lower side of the lamp does not enlight as the upper side.
Can anybody help me?
Thank you.
