Clay Pots
Started by abedsabeh, June 12, 2012, 06:45:21 AM
abedsabeh
As Usual, modeled in Maya.
Josh3D
Great texture Abed, love the feel of this image.
tsunami
Yes real good work,..for me u got your goal, nice texture and good models!.
Could you share your lightning setup with us?
Regards
Ed
Abed -
Your renders always have a nice depth.
Do you use the KeyShot DOF, or do you add the blur in Photoshop?
Ed
fario
abedsabeh
Quote from: tsunami on June 12, 2012, 03:01:01 PM
Regards
Thanks! Of course I will share the setup with you:
I used hdri-locations_factory_4k.hdz
Contrast: 1.368
Brightness: 0.49
Lighting Environment disabled, and I used in my model a rough reflected cube with normal map opened from 3 sides to create the room.
No color correction or post has been done. It was straight from KeyShot.
abedsabeh
Quote from: Ed on June 12, 2012, 04:47:58 PM
Abed -
Ed
Yes Ed, I love to use the DOF in KeyShot, it is great! Also you can never get a nice and controlled DOF by using the blur effect in Photoshop, unless you use the lens blur effect and it is not easy since you have to split your scene into layers or create a zDepth to control it properly.
tsunami
Quote from: abedsabeh on June 13, 2012, 04:58:58 AM
Regards
Contrast: 1.368
Brightness: 0.49
Thanks a lot to share your lighting setup, this is helping and improving a lot. to understand keyshot power world...
thanks
Regards
feher
