Mustang - WIP
Started by Hallgren, June 18, 2012, 03:09:45 PM
Hallgren
Hello Guys, I just started to render my Mustang.
If you have some suggestions how to make the scene better, please post your comments  :)
I know i need to replace the material on the brake disk and i forgot to place the Oz logo on the back tire.
Im quite the beginner at Keyshot, but im trying to learn.  8)
tsunami
Hi maybe, you should play with light environment, because at the moment seems a "toy car"....this is mine idea.
But is a good starting..
Regards
Hallgren
Should i use startup hdri and place additional lights or should i place an indoor/outdoor enviroment instead and place additional lights on that one?
Thank you for the help.
There are about 40 environments that ship with KeyShot. Try them. Rotate them, change the height, adjust the brightness and contrast if needed. if you have the Pro version, you can add additional light sources using the HDR Editor.
