Author Topic: My audi R8 details level 2  (Read 2792 times)
Angelo
  • Guest
« on: August 01, 2012, 12:19:13 pm »
did the cutouts today for the front testing some renders for fun its starting to look awesome, but still a long way to go!
Offline feher
Re: My audi R8 details level 2
« Reply #1 on: August 01, 2012, 01:54:39 pm »
Looking good. Can't wait to see the final.
Thanks for sharing.
Tim
Angelo
  • Guest
« Reply #2 on: August 01, 2012, 03:26:19 pm »
thnx Tim!  :)
Offline Dylan
« Reply #3 on: August 02, 2012, 08:44:29 am »
From what I can see, the modelling looks clean and sharp. Well done so far.
Angelo
  • Guest
« Reply #4 on: August 03, 2012, 12:13:24 pm »
yes clean, thanks to the "match surface" command in rhino and the zebra analysis it has helped me alot, later i am going to trim and blend some sharp edges so it gives this realistic look still much work to do!
Angelo
  • Guest
« Reply #5 on: August 03, 2012, 12:16:55 pm »
when im done with the modelling im going to study keyshot better so i can also render like a pro ;)
Angelo
  • Guest
« Reply #6 on: August 05, 2012, 03:57:12 pm »
i forgot to mention i added some blur from photoshop the first one became good but the last 2 ones where a bit off i think, my first try tho practice makes perfect :)
Offline Dylan
« Reply #7 on: August 06, 2012, 05:27:53 am »
If you are looking for DOF effects in Photoshop, do the blur on several layers, in small increments. Then use a soft eraser on each layer until it looks right.
Angelo
  • Guest
« Reply #8 on: August 06, 2012, 10:41:23 am »
ok thnx will try that next time
