Author Topic: Animation crashing on 25th frame on a 25FPS movie!  (Read 2730 times)
Offline rfollett
« on: August 30, 2012, 01:14:12 am »
SO it has crashed now in exactly the same place, frame 25 as it finishes it crashes.. I have run this twice now and same both times. Any ideas please???
Offline KeyShot
Re: Animation crashing on 25th frame on a 25FPS movie!
« Reply #1 on: August 30, 2012, 09:48:14 am »
Can you contact support or share your model with support? There are no known issues related to the 25th frame at 25 fps.
Offline rfollett
« Reply #2 on: August 31, 2012, 12:00:25 am »
Yes, how do I do this?
The issue seems to happen if I create the file on one machine 64Bit and transfer file (BIP or KSP) to 32 Bit machine
  • Guest
« Reply #3 on: September 07, 2012, 04:53:59 pm »
Most likely you are running out of memory. Could that be the case?
