Non horizontal ground plane
Started by Robert V., September 25, 2012, 03:12:25 PM
Robert V.
Hi keyshot team,
Would it be possible to add a rotatable ground-plane?
For example: I have a backplate with a road which "climbs 18%" (at an angle so to speak), the shadow of the car will always look like the ground is flat horizontal. This would add a lot to the realism and the range of purposes keyshot can be used for.
thanks,
Robert
PhilippeV8
you can tilt the camera a bit and set it all up .. however, I'll put a +1 on the moving ground plane.  It would help a lot when you've got to render a wall-mounted object.
