Author Topic: mapping label on box  (Read 5065 times)
Offline nagelibre
« on: September 28, 2012, 06:19:46 am »
I'm looking the best way (or quicker) to map a box/cube with a label perfectly on each face. Do I have to create a single label for each face or is there any trick to label the box in one time with a unwrapped map label?
Thanks for advices
Fred
  • Guest
Re: mapping label on box
« Reply #1 on: September 28, 2012, 06:26:56 am »
Depending on your modeling software you may be able to uv map the model, and then apply the graphic in one step. Otherwise a single label per side is your answer.
Offline nagelibre
« Reply #2 on: September 28, 2012, 07:03:10 am »
Ok , thanks for your quick answer... and I think I will have to do it face by face, too bad!
