FIRE
Started by techdoku, October 04, 2012, 03:21:42 AM
techdoku
hi folks,
is there a possibility to create fire (texture) inside ks3?
i did this one in photoshop after rendering the stove without glas and without fire.
but it would be cool (hot) to create 3d fire so you can shoot different camera positions with same fire.
PhilippeV8
add the fire as a texture to a plane inside your stove .. then render with glass ... simple, no ?
techdoku
thanks man,
great idea!
it works but is it possible to make the black fadeout transparent so you can see a bit what is behind the fire?
i tryed different settings but without getting the desired result.
PhilippeV8
Make the fire a PNG file with transparency.  Then aply it as a lable to the surface.
Check this thread:
http://keyshot.com/forum/index.php/topic,4362.msg18499.html#msg18499
