3930K@OC4.4GHz, Rampage IV Extreme, 32GB Dominator Platinum, 84fps
Started by jiyang1018, October 24, 2012, 11:22:27 PM
jiyang1018
Some detailed information generated by AIDA64 was deleted because it is irrelevant.
CPU is cooled by Corsair H100 with stock fans pushing air towards radiator. Radiator is mount in 5.25 bay vertically in Silverstone Raven 03 case.
Chassis fan 1 and 2 are the stock fans from H100. Rampage IV Extreme CPU fan headers support only pwm fan control, neither do Corsair H100 pump fan headers. RIVE motherboard optional fan headers can only be controlled in BIOS setting, but not fan control curve. That is why I connected H100 stock fans to chassis fan header #1 and #2.
    Operating System                                  Microsoft Windows 7 Professional 6.1.7601 (Win7 RTM)
    Date                                              2012-10-25
    Time                                              02:04
--------[ Summary ]-----------------------------------------------------------------------------------------------------
    Computer:
      Computer Type                                     ACPI x64-based PC
      OS Service Pack                                   Service Pack 1
    Motherboard:
      CPU Type                                          HexaCore Intel Core i7-3930K, 4400 MHz (44 x 100)
      Motherboard Name                                  Asus Rampage IV Extreme  (1 PCI-E x1, 5 PCI-E x16, 8 DDR3 DIMM, Audio, Gigabit LAN)
      Motherboard Chipset                               Intel Patsburg X79, Intel Sandy Bridge-E
    Display:
      Video Adapter                                     NVIDIA GeForce GTX 680  (2048 MB)
      3D Accelerator                                    nVIDIA GeForce GTX 680
      Monitor                                           Dell 2408WFP (Digital)  [24" LCD]  (G283H929114S)
      Monitor                                           Dell 2408WFP  [24" LCD]  (G283H8BI1EES)
      Monitor                                           Dell 2408WFP  [24" LCD]  (G283H87L11HS)
    Storage:
      Disk Drive                                        KINGSTON SH103S3120G ATA Device  (120 GB, SATA-III)
      Disk Drive                                        WDC WD6400AAKS-00A7B0 ATA Device  (640 GB, 7200 RPM, SATA-II)
      Disk Drive                                        WDC WD7500AACS-00D6B1 ATA Device  (750 GB, SATA-II)
  [ BIOS ]
    BIOS Properties:
      Vendor                                            American Megatrends Inc.
      Version                                           2105
      Release Date                                      08/04/2012
      Size                                              8192 KB
--------[ Overclock ]---------------------------------------------------------------------------------------------------
    CPU Properties:
      CPU Alias                                         Sandy Bridge-E
      CPU Stepping                                      C2
      CPUID CPU Name                                    Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
      CPU VID                                           1.3711 V
    CPU Speed:
      CPU Clock                                         4400.0 MHz  (original: 3200 MHz, overclock: 38%)
      CPU Multiplier                                    44x
      CPU FSB                                           100.0 MHz  (original: 100 MHz)
      Memory Bus                                        800.0 MHz
      DRAM:FSB Ratio                                    24:3
--------[ Memory ]-------------------------------------------------------------------------------------------------
    Physical Memory:
      Total                                             32716 MB
    Extreme Memory Profile v1.3:
      Profile Name                                      Enthusiast (Certified)
      Memory Speed                                      DDR3-1600 (800 MHz)
      Voltage                                           1.50 V  (Memory Controller: 1.20 V)
      @ 800 MHz                                         9-9-9-24  (CL-RCD-RP-RAS) / 41-208-2-6-12-6-6  (RC-RFC-CR-RRD-WR-WTR-RTP)
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Pretty good temperatures on that CPU at 1.37V!
I'm getting max. 75 deg. C (72 average) with 4.6GHz at 1.29V.
Are you doing watercooling?
jiyang1018
forgot to mention.
CPU is on Corsair H100
I already changed the fans to pushing instead of pulling, but the picture was take before that.
I am still waiting cougar vortex 120 pwm fans to drop price.
jiyang1018
Original post was corsair stock fans on push configuration, chassis fan 1 and 2 are these two fans and speed controlled accordingly by cpu temperature.
I just purchased 4 cougar vortex 120mm pwm fans and set my corsair H100 to push and pull with the new cougar fans, and all fans connected to H100 block pwm fan headers. even I have 4 fans now, my computer is much quieter than before under full load.
here is the result:
