Author Topic: "Another Corner in Winslow" + a tip on ground shadows  (Read 3493 times)
Offline Speedster
« on: November 04, 2012, 04:42:01 pm »
Hi all;
In my previous post (http://keyshot.com/forum/index.php/topic,4736.0.html) Egon made some great suggestions on how to darken ground shadows, which all of us face often.  Thanks, Egon!
I tried a slightly different approach on my "Time Warp- Another Corner in Winslow" rendering.  I first Rendered the beauty shot, and for this I used the Effects Vignette on the Settings tab.  Then I disabled the vignette and pulled a clown pass as a TIFF with alpha channel.  Dropped the clown TIFF into Photoshop, "Placed" the beauty shot and linked the layers.  Copy and hide the clown layer for safety sake.  Then select and delete the clown part of the copied layer.  Move the new "shadow only" layer above the beauty shot and use either levels or a curve adjustment to darken the ground shadow to suit.  Bingo!
Offline DriesV
  • Administrator
  • Total likes: 33
Re: "Another Corner in Winslow" + a tip on ground shadows
« Reply #1 on: November 05, 2012, 12:36:52 am »
Bill,
To show you how I typically control ground shadow intensity, I have uploaded a PSD file.
Basically it boils down to rendering a beauty and B/W flat pass.
I then import the beauty pass into PS and make a copy on top of it. I use the flat render pass as a layer mask on the copied layer to extract just the components without ground shadows. I put original imported layer to blend mode multiply. I make copies of that layer and play with opacity levels to control ground shadow intensity.
This method works very well for me.
« Last Edit: November 05, 2012, 12:39:27 am by DriesV »
Offline DriesV
  • Administrator
  • Total likes: 33
« Reply #2 on: November 05, 2012, 01:34:21 am »
Same goes for ground reflections...
Of course all of this masking becomes obsolete when Luxion decides to give us shadow & reflection passes lovely embedded in our rendered TIFFs... *wink* *wink*  ;)
« Last Edit: November 05, 2012, 02:09:28 am by DriesV »
Offline Speedster
« Reply #3 on: November 05, 2012, 06:33:21 am »
Thanks from all of us, Dries!  Actually very similar to my approach, but it seems simpler.  And I agree- add my additional *wink*!
Deacon
  • Guest
« Reply #4 on: November 05, 2012, 06:42:37 am »
That's the same method I use Dries and it works quite well. Yes, it would be a treat if Keyshot would export ground shadows and ground reflections on a separate layer, but for now, this method satisfies the need.
Paul
Offline DriesV
  • Administrator
  • Total likes: 33
« Reply #5 on: November 05, 2012, 07:13:37 am »
Glad to have been of service!
@KeyShot moderators: maybe there should be a tutorial section in the Share subforum?
A lot of useful hints & tips get scattered around the forum too much I think...
« Last Edit: November 05, 2012, 07:16:13 am by DriesV »
Offline swashbuckler
« Reply #6 on: November 05, 2012, 07:16:50 am »
Thanks for uploading the files, it's always nice to see some workflows!
Offline Speedster
« Reply #7 on: November 05, 2012, 07:41:13 am »
Quote
Great idea!  How about it, Thomas?
