HDRI KeyShot Editor buggy?
Started by EGON, November 09, 2012, 11:28:02 AM
EGON
Every time it asks my to save changes I save and then it changes all my settings. Am I doing something wrong?
PhilippeV8
On my side, it makes KS crash 40% of the time when I try to save the part ... but I have a feeling this has to do with memory issues, being on WinXP 32
I often want to render without saving the changes, but can't, and "discard" does just that- dumps the changes.  We often just want a quick tweak without committing to a saved hdz.
EGON
Yeah. I spend a lot of time tweaking the environment and to have it all go away as soon as I hit save kills me. Cool feature though.
That's odd. Are you on the latest build?
EGON
Yes Thomas. If I save file before first render everything is fine.
Bruno F
I start a fresh scene and follow the steps below without any problems.
1.  Open the HDR Editor and make changes
2.  Click the Render button
3.  Click Render within the Render Options window
4.  Click Save when asked to save changes to the HDR Editor
5.  Once the rendering is done, close the render progress window
6.  The changes made prior to the render are saved and visible inside the HDR Editor
Let me know if this is working properly for you.
Imz
Any updates on this? I haven't had any luck saving the changes I've made to HDRIs... definitely a little frustrating.
Imz
Can you make sure that your permissions are set properly. We use it here all the time, and don't run into any issues as far as saving goes.
EGON
Just did five saves in a row. Not working. I'm on a Mac 10.6.8
EGON
Just did a screenshot for a comparison. It saved it properly . It seems to get buggy when I use the pins. I think.
