Author Topic: HP Z820 2x Xeon E5-2680 3.1GHz - KeyShot 3.3.33 - 156.6fps  (Read 7964 times)
Offline DriesV
  • Administrator
  • Total likes: 38
« on: December 05, 2012, 07:39:31 am »
  • HP Z820 Workstation
  • 2x Intel Xeon E5-2680 2.7GHz (Turbo Boost capped to 3.1GHz when all 16 cores are loaded)
  • Intel X79 chipset (proprietary HP motherboard, 158B)
  • 32GB RAM
  • Windows 7 Professional 64bit
156.6fps on KeyShot 3.3 Pro 3.3.33
KeyShot is a blast on this system!  ;)
greetings,
Offline PhilippeV8
Re: HP Z820 2x Xeon E5-2680 3.1GHz - KeyShot 3.3.33 - 156.6fps
« Reply #1 on: December 05, 2012, 07:48:08 am »
*thumbs-up*
Offline tfinlay
« Reply #2 on: December 05, 2012, 07:57:37 am »
That's a monster!  About 10x the speed of my crappy laptop.
Now overclock it and see if you can crack 200
Offline DriesV
  • Administrator
  • Total likes: 38
« Reply #3 on: December 05, 2012, 07:59:11 am »
You can't overclock the newest generation (E5) Xeons.  ;D
Also, this thing is 16 (!) times faster than my old system!
Quite honestly, it is ridiculously fast. Almost 2 times faster than my overclocked 3930K (4.4GHz, 83fps) based system at home as well.
« Last Edit: December 05, 2012, 08:02:37 am by DriesV »
Offline DriesV
  • Administrator
  • Total likes: 38
« Reply #4 on: December 06, 2012, 06:00:23 am »
At full load and after several hours of rendering the hottest core is hitting 75 deg C (according to HWMonitor). All cores stay nicely between 70 and 75 degrees.
This is with fan speed setting in BIOS at level 3, which brings acceptable noise. Level 7 is the maximum speed, but then the Z820 sounds like a JET!!
Is 75 deg C acceptable for these CPUs, in the long run?
greetings,
« Last Edit: December 06, 2012, 06:06:44 am by DriesV »
Offline tfinlay
« Reply #5 on: December 06, 2012, 06:59:51 am »
Wow, that is very hot.  Of course 130W is a lot of heat to dump through a processor continuously.
What coolers are you running?  LGA 2011 coolers aren't common, and many are server case (rack mount) stlye low-profile coolers (consequenlty, they sound like a JET - we have an older dual xeon LGA 2011 machine in the office with the exact same issue).  If your case can handle it, 2 of these might solve your problem: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024  They will run much cooler and make a lot less noise.
Offline DriesV
  • Administrator
  • Total likes: 38
« Reply #6 on: December 11, 2012, 11:41:43 pm »
For any Z820 users out there:
It might be worthwile to increase idle fan speed in BIOS from factory default ...... to ***....
This introduces some humming noise from the fans, but CPU temperatures never go above 64 deg C on a dual E5-2680 system.
With fan speed setting **.... I got 75 deg C max.
greetings,
« Last Edit: December 11, 2012, 11:43:58 pm by DriesV »
