Bellasimo Colour Selector
Started by Juarez, December 13, 2012, 11:41:28 AM
Juarez
We're using the VR tool to create some great interactive content for clients.
Hope you like it.
M.
http://www.project-samples.wingspan-design.ca/documents/Keyshot/VR100-Wingspan-Roaster.html
Juarez
I promised Thomas I would do a tutorial on this colour selector.
You can download the VR files at this link:
http://www.project-samples.wingspan-design.ca/documents/wingspan/VR100-Wingspan-Roaster.zip
Steps to produce this VR:
1.  Decide how many colours (5 colors used; this will be used to calculate the vertical frames)
2.  Decide on the turntable rotation frames (5 degrees gives 72 frames for 360-degress)
3.  Render Hemispherical VR with the correct Horizontal Frames (5 degrees gives 72 frames for 360-degress)
and 2x the vertical steps (5 colors x 2 steps each = 10 steps, or 9-degrees)
If you look in the VR directory, you will see that each vertical frame has a set of horizontal frames up to 72.
Each image is labelled with 2 numbers 0_1 up to 0_72, then 1_0 to 1_72, up to 9_0 to 9_72.
What we are going to do is make new horizontal frames for each color, then rename them to match the Hemisphere VR format,
and replace the vertical images with new color sets.
4.  Render each colour in Turntable mode with same settings as 2 (5 degrees gives 72 frames for 360-degress)
5.  You will now have 5 different turntable VR
fario
