Render queue issue
Started by Chazz, January 10, 2013, 04:59:53 AM
Chazz
When I render in queue all I get is black pictures on my hard drive.
Rendering a single picture works just fine.
Anyone has an idea why it is so?
K
Airwaveflyer
I have found that problems like that is most often texture-related.
Check paths to textures...in this case I would concentrate on the environment. Manually set the environment to a hdr/exr-file for each render before adding them to the queue.
Accessrights to textures.. check that you have permissions correctly set. (could be that the queue runs under a different user that lacks permission..maybe...wild guess.)
writepermissions to the outputdirectory..
My guess in short..check all permissions...
Robb63
I just go the same thing (all silhouetted images), using Network rendering. My render queue works fine though??
