Porsche 550A 1957 James Dean Dream
Started by tsunami, January 12, 2013, 03:34:14 PM
tsunami
..James Dean car Dream..1957 cabrio special version
Rabe
Gorgeous... What kind of light setup are you using?  Seems like maybe some of the highlights ought to follow the contours of the curves a bit more smoothly, but would depend on the lighting I suppose... I am jealous of how realistic you manage to get these things...
tsunami
Quote from: Inkling on January 14, 2013, 05:36:32 PM
Thanks Inkling, well i used hdri scene for lighting scenes ;-)....
And thanks for your comment and suggestions
regards
Esteban Rosas
love the rims aspect! amazing realistic
tsunami
Esben Oxholm
Nice! I really like how the surface of the car isn't perfect and makes the reflections wave a bit... like in real life. Awesome.
tsunami
Quote from: Esben Oxholm on May 23, 2013, 11:48:52 AM
Thanks a lot! yes...when i can i always try to get reality on my works..but not always it's happens ;)
However i'm working in a new shot about this porsche..and u will see soon..
regards
Aldo
Esben Oxholm
Quote from: tsunami on May 23, 2013, 03:12:50 PM
regards
Aldo
Did you by the way create the bulgy surface in your CAD-program or is it by a bumpmap or something created directly in KS?
tsunami
Quote from: Esben Oxholm on May 24, 2013, 02:17:49 AM
regards
Aldo
Nope, is it only a bump map with specular and opacity.. i created it before start render..with some adjustments..
Esben Oxholm
Quote from: tsunami on May 24, 2013, 04:27:56 AM
regards
Aldo
Cool. Could you share some information about your bump and opacity map? I'm trying to create the same effect on a plastic surface, but just can't get it right.
tsunami
Quote from: Esben Oxholm on May 24, 2013, 05:20:46 AM
regards
Aldo
Hi sure,
i started using images in attachment, and melt them ,(i tried many time, untill i found a melt way to use on my model), so i got my bump.
After that i created opacity and specular using Ps, and you can found a good keyshot tutorial for that at:
http://keyshot.com/textures-in-keyshot-creating-bump-color-specular-and-opacity-maps-really-fast/2012/
take a look on it, and let me know..but i don't know if with plastic material, the result will be the same.U must try on it..
Let me know..
Aldo
edwardo
This is so nice man. Its as close to realism as iv seen. Proper hand-beaten panels, rivets, dinks, dents, rust on the rims, and even gravel stuck to the underside of the front tyres!! Beautiful modelling, appreciate it!
