Diffuse pass?
Started by Saloff, January 26, 2013, 10:40:09 AM
Saloff
Hi All,
How do you render diffuse pass in Keyshot? I must be missing something...
Thanks,
S
Apply a diffuse material to the entire model. Would that do it?
Saloff
would that enable me to have a render without highlights and shadows?
Yes - it will not have highlights. If you don't want shadows, then turn them off. Or you could use the "flat" material.
You can disable 'self shadows' in the settings tab. This eliminates the casting of shadows on geometry.
Ground shadows can be toggled off in the environment tab.
As Thomas suggests, try the diffuse material. Or pick paint, advanced... material with specular color black.
Saloff
Thank you, guys! I am giving it a try.
