How to see axis in the detail view
Started by bluenite, January 28, 2013, 03:37:21 PM
bluenite
When you increase (zooming) the view of object for detailed editing (move, scale), axis does not fit in the window - see sshot 1+2.
http://imageshack.us/a/img194/4999/ss1ym.jpg
http://imageshack.us/a/img708/1268/ss2hg.jpg
How to achieve this in order to see and use these axis for move selection in the bigger detail?
thx for advice
Peter
bluenite
sure I can..
when you step out with the camera, close-up view is reduced ...
maybe I cannot accurately describe the problem, but I think it solves all who use changes in location or scale.
It is not always possible to do this in 3d editor (Rhino)
I meaned some tip to do it.
PhilippeV8
That is an issue ...
If I get this right, it's the (red-blue-green) gizmo that is stuck to the center of the bounding box of an object if you chose to move it (or scale or whatever) .. If you need to position a bigger part very acuratly, you sometimes need to zoom in on an edge or a place where one face needs to toch an other objects face ... but then the gizmo is out of view .. unless you manage to ori
PhilippeV8
(In 3D via composer you've got an option that you can turn on/off, which lets you move the gizmo without moving the object)...
