Author Topic: How did PhilippeV8 do this?  (Read 3611 times)
Offline eon_designs
« on: January 30, 2013, 08:43:37 am »
Looking through the forum I came across this:
http://keyshot.com/forum/index.php/topic,4362.msg18499.html#msg18499
How did they get the fibre effect to the side of the material? I understand that you can add an alpha channel, but his looks like it is going to have two different areas to create the mask?
This is what PhilippeV8 said about the image
Quote
Top part shows the situation as I had it ... not very realistic edges!
The botom part shows the result on the left edge, and the untextured geometry on the right edge.
Has he somehow created a texture map with transparency (alpha channel)?
Thanks. eon
