Render problems
Started by rainycat, February 04, 2013, 07:47:04 AM
rainycat
Anyone had this problem before?
Image looks fine in the live window, but the resulting render output is messed up. I would guess its a mapping issue? Or render settings too low?
Model is from Solidworks (from client, I have no control over it) Keyshot v3
rainycat
Here's the actual render
KeyShot
That looks odd. It looks like the lighting is different on some of the tiles. Is it consistent? Are you using network rendering? Any chance you can share the file with support@luxion.com ?
rainycat
I dont have authorisation to supply the base files unfortunately.
PhilippeV8
Perhaps you can recreate the same issue with a simple 3D geometry ?
ADH
I am having the same problem with a brushed metal texture. It doesn't always happen...only sometimes and rendering the same model!
Does anyone have an idea why this is happening? I have tried to change the settings, but nothing works...
Thanks,
A.
p.s:I am using Keyshot 4 Pro.
