big size image. Memory crash
Started by simonin, February 08, 2013, 12:09:53 AM
#15
Quote from: PhilippeV8 on March 19, 2013, 02:08:38 PM
It's time for many upgrades ... and so it has been for +2j ...
I am slowly growing numb of frustration of all those crashes  :-\
Philippe, not kidding on this one.
I was in the same boat for a while +/- 1.5 years ago.
Working with SolidWorks assemblies with hun-dreds of configurations, easily pushing +2GB memory for SLDWORKS.exe alone. ???
Constant crashes were driving me mad.
I also bumped into Windows 7 64bit implementation reluctance. ::)
What helped me to get a better workstation and modern OS was to make a cost-benefit analysis (CBA). Just like I had to make them in college to evaluate the soundness of investments for ALL stakeholders. ;)
I actually made a spreadsheet, comparing the cost of a new workstation (and accompanying load on IT) to the the time I would win working on projects. A week later I was on W7 x64.
I can really recommend doing that. Try to get IT and finance on board from the get-go.
You have to emphasize that YOU are the expert in your domain for your company. Because frankly, IT probably has no clue about what you're doing. :)
It depends a bit on the company culture and structure too. One advantage I have is that R&D is a relatively small group of people (meaning: not far from being understaffed ;)). I guess the smaller the team is, the smaller the 'tolerance for wasted time' is. ;D At least that's my theory about it.
In all fairness...and I'll just put it bluntly:
Judging by the work that you do, working with the assemblies that you have...it's a disgrace that you can't work on a modern 64 bit OS. Like you said: the OS is crippling the hardware potential. :o
KeyShot
Hi Philippe,
It is effects under settings (bloom and vignetting). These require a post-process on the framebuffer, so even if you use exr output they require the full framebuffer in memory, which I think is why you see the memory request when you press the render button.
PhilippeV8
Thnx, I will check.
I rarely use those so I doub't they're turned on.  But I will check tomorrow.
(It's 3.33 in the night here ... I'm up cus my youngest won't sleep  :-\ )
