Surface or Sub-Object Selection Possible in KeyShot?
Started by Kinetic Vision, February 21, 2013, 11:23:56 AM
Kinetic Vision
There is no sub-object or surface selection in KeyShot is there? For example, I have a cast part with machined surfaces and want to use two different materials on the same part. Do these surfaces need to be differentiated in my CAD program or can I somehow do that in KeyShot?
Thanks.
#1
Just apply different colors (on the part level) to the faces that you want to have separate materials/textures.
KeyShot will interpret the differently colored faces as separate objects.
PhilippeV8
Quote from: DriesV on February 21, 2013, 01:24:08 PM
... in your CAD software ...
... upon importing.
Quote from: PhilippeV8 on February 21, 2013, 11:39:20 PM
... upon importing.
Why you nitpicker... ::)
Indeed, that's the full procedure. :D
PhilippeV8
Not meant to pick any nit ...
Intention was to make sure it's 100% clear that it's not in KS you got to look for giving faces a separate color ..  :D
