su-27 flanker
Started by Saloff, February 22, 2013, 10:23:49 AM
Nice - jet stream may be a bit too thin?
PhilippeV8
I like it !
Not sure if the jetstreams are too thin .. they do grow quite a bit, but way further back behind the plane.
This is not an su-27 flanker tho ... it's an su-27 drone  8) :P  Where's the pilots ?
tsunami
Lovable!very good work i like it!!!!!!!!!!!
Saloff
Quote from: PhilippeV8 on February 22, 2013, 11:16:48 AM
I like it !
I thought I managed to hide the fact that it is in fully automatic flight mode:)
cgrill
Wow! How much of the sheet metal lines are the model vs. post render work? The texture mapping is crazy! Curious how you did that too!
EGON
I have a pilot.
AWHeathcote
That's insane, Nice work
jhiker
Saw one of these at an air show once - it came screaming down the runway about 50ft off the deck, stopped - yes, stopped, in mid-air - turned the nose up to vertical - afterburners on, and straight up like a rocket until it was out of sight.
One of the most impressive things I have ever seen....
