KS4 PRO floating stays small in the taskbar after export form SW plug in
Started by eric, February 24, 2013, 11:50:13 AM
eric
when  I export from SW2013 using the plug in on one of my WIN7 X64 machines KS4 stays small (minimized) in the taskbar by default.
I can only see the file when I mouseover it in the taskbar and maximize by RMB.
starting KS4 floating from the startmenu does'nt show this problem.
the other machines with the exact same configuration I have seem to work ok.
what could be causing this?
Hi Eric,
I've came across this bug as well and has been reported - should be fixed in the next update.
Thanks,
Chad
multitech
I ran into this same problem with Keyshot 4 running on Windows 7-64 Pro.  Keyshot was opening minimized and would not open to a full or partial window from the taskbar.  I was able to get into Keyshot by opening the Task Manager - Applications, right click on Keyshot 4 and Maximize.  Undock all the menus.  Should function normal again.  May need to be closed and reopened.
Mike   :o
There's a couple other options as well that may help until we fix this bug:
- Hover your mouse (the arrow not your actual mouse  ;D ) over the KS shortcut to show the mini preview. Right click on the preview and choose maximize.
- If KS opens "minimized" everytime, you can go into the HTML file in the KeyShot 4 folder (should be under "My Documents" in most cases) and change the x and y to = 0 of this parameter: <mainwindow_position x="0" y="0"/>
