Author Topic: KS4 plugins for WF5/WF4 links are bad.  (Read 2488 times)
Offline idesignstuff
« on: February 28, 2013, 01:33:03 pm »
I went to grab the WF4 plugin for KS4, and the link on this forum for the plugins gave me a 404 error.
I read the path in the link, and it's pointing us to the WF5 foder to pull the WF4 plugin, and vice versa.
FYI, if you want them, you can edit the url to be correct, and it pulls just fine.
here's the link for the WF5 plugin:
http://keyshot.com/install/plugins/proe/wildfire4/keyshot4_wildfire5_plugin_2.0.exe
And here it is, corrected:
http://keyshot.com/install/plugins/proe/wildfire5/keyshot4_wildfire5_plugin_2.0.exe
And for WF4 from the link in the forum:
http://keyshot.com/install/plugins/proe/wildfire5/keyshot4_wildfire4_plugin_2.0.exe
And corrected:
http://keyshot.com/install/plugins/proe/wildfire4/keyshot4_wildfire4_plugin_2.0.exe
  • Guest
Re: KS4 plugins for WF5/WF4 links are bad.
« Reply #1 on: February 28, 2013, 01:37:18 pm »
Fixed - thank you.
