Author Topic: Label Bleeding Through  (Read 4037 times)
Offline keaneray
« on: March 04, 2013, 04:45:02 pm »
I have encountered a problem with a label I'm applying to the front of a part. It bleeds through onto other surfaces. Is there a way to stops this?
Offline Chad Holton
Re: Label Bleeding Through
« Reply #1 on: March 04, 2013, 06:59:29 pm »
Have you tried adjusting the "Depth" parameter under the label options? If not, just crank it down a bit.
Offline keaneray
« Reply #2 on: March 04, 2013, 07:28:49 pm »
Thanks Chad, the depth adjustment worked a treat.
