KeyShot 4 Plugin Crashes with Sub Assemblies
Started by m2tts, March 07, 2013, 07:24:54 AM
m2tts
I have a SW assembly that contains two subassemblies. When using the Keyshot 4 plugin; choosing "render"; SW crashes. Works fine with assemblies with just parts.
The assembly with subassemblies imports just fine; but SW will crash if I try to update with live linking. KeyShot says it's waiting for a connection to import the updated geometry.
Make sure you install the latest plugin from the "Plugin" section or www.keyshot.com/plugins.
m2tts
Hi Thomas, I've updated the plugin to 2.0.1 and it still crashes SW.
Any chance you can share the file? Send directly to me via keyshot.wetransfer.com.
m2tts
Hey Thomas, I have transferred the assemblies causing the trouble. Please treat these as confidential.
I have experimented with other test assemblies and while they don't crash SW, they also do not show any Live Linking; even though that is checked. I was trying to recreate the crash as I had a hunch it was because of using "use a sub-assemblie's explode" in a higher level assembly explode view. That doesn't seem to be the issue however.
We fixed the issue. I e-mailed you the links, and updated the links on www.keyshot.com/plugins.
Please let us know how it works.
m2tts
The new pluging solves the crashing issue, but it has broken Live Linking. We realllllly like the new Live Linking feature as it can easily show models in various states of motion (flipping subassemblies), and exploded views.
Spoke with the developer. You can select the changed parts and then hit update. This will then force the update and move the "changed" parts over.
m2tts
Great - right now we can't detect these changes. Same when you just change the color on a part. You will need to select it to force the update.
We are of course looking at improving this, and will hopefully able to auto-detect these types of changes.
m2tts
But it was doing this before the 2.0.1 update. I know I saw an assembly that a rotating part in it update without highlighting it first. Also saw an exploded view update with an assembly with just parts in it.
