KS4 takes long time to boot
Started by Esben Oxholm, March 12, 2013, 06:59:39 AM
Esben Oxholm
Hi.
When i start up KS4, it uses a minut or so to refresh the matrial library.
I can't start working until it's done with that.
Is it supposed to take this long?
Is there any way to make the loading time shorter?
Compared with KS3 it only took a few seconds as I recall.
Best regards
Esben
KeyShot
Are you running the latest version 4.0.74? We did make a fix that could cause the library to refresh too often.
Esben Oxholm
Yes, it is 4.0.74.
Is it possible to only refresh manually when needed?
Claus Jensen
Are your materials located on a network drive?
How many materials do you have in your library?
Is KeyShot re rendering the material sphere?
Esben Oxholm
Moved the folders from a network drive to a local drive.
Now it only takes a second. Thanks!
I had to customize each folder seperatly, though. When specifying location for all folders, it was set back to the old after restart.
Thanks for your help.
