Minimalistic carbon fiber ring
Started by Arian Shamil, March 12, 2013, 11:00:38 AM
Arian Shamil
Ciao to everybody...
I saw a lot of masterpiece here on Keyshot forum so forgive me if my renders are "poor".
I'm not using Keyshot from a lot of time so I'm learning it day after day....and also sorry for my poor english :D
it's my first post here on Keyshot forum.... :)
Despot
I'm afraid it does not look like Carbon Fibre to me, increase the tiling amount by a factor of 2 and make the material more reflective - it should look like it has a coating...
And add a bump map to add some depth to the carbon fiber.
Arian Shamil
Thanks a lot for the comment :)
I know i'm really really really far from a perfect render!
Your suggestions are precious for me!
I'm here to learn from you as much as possible!
P.S
Your carbon ring is AWESONE!
Despot
#4
This one was done by making a copy of the carbon fibre geometry, then scaling it slightly to produce a clearcoat layer
So in KS use a diffuse carbon fibre material on the bottom layer and a glass material on the top for nice reflections
I've changed the original image, this is my last attempt using a different texture map
J
Arian Shamil
Thanks a lot to had replied to me again..
Yes i'm trying too to use a glass material on the bottom layer and the result is nice....But i still have some problem with the carbon texture....i'm searching the right setting to don't see the texture board...i've always problem when i'm repeating a texture on a surface/body plane ecc....the texture are "specular" and they create some visual problem...
Sorry guys for my primitive english :(
Arian Shamil
I've just did some "upgrade" to my ring...
Do you think it looks better?
I know it's still far to be perfect, but i hope it just a few better than before :)
tsunami
Quote from: biomechanic on March 12, 2013, 03:57:33 PM
J
follow biomechanic suggestions....this is great..
