Let's See Your Amazing Fractal Shots!
Started by Josh3D, March 14, 2013, 08:48:33 AM
Despot
Hi Thomas - yes I am
When I open the file, what should I see ?
J
Despot
Well I just see the grey environment, nothing else
J
Despot
Are you using 4.0.74, and doing a simple File > Open?
Well that answers that. Is it in the scene tree?
Despot
Yeah, it's in the scene tree and when I go to the material I can adjust parameter settings but nothings visible...
When I rotate around the scene, nothing is there
I just give up...
J
Despot
Can I just say I'm using a legitimate copy of KS... I can send you my serial number if it is required
Im running KS on a Windows 7 64bit platform
Gotta admit this is the first time I've ever seen a blank render viewport on file open...  :'(
J
Check the scale of the object, and the camera distance.
Despot
Tried all of that, nothing works, still just an empty scene, visually anyway...
J
Despot
Can somebody open the file and re-save it, then upload it for me to download please.
Just clutching at straws here...
J
#26
Here you have it.
Strange...opens just fine on my machine using the exact same KS4 version...
I changed the settings a bit. maybe that helps.
It does seem like the scale changes when reopening. The scale of the fractal model should be at '2'.
Despot
Hi Dries, thanks, but it didn't work
I just see a blank render window, rotating, changing scale and/or camera distance does nothing at all
Not a fractal in sight...
I'm beginning to think it is a KeyShot conspiracy...  ;)
J
Despot
Re-installed KeyShot...
Still nothing
Luxion please help...
J
r u on 32bit or 64 biomechanic ?
