Poll
mirror wrong
cbh
0 (0%)
gjjkl
0 (0%)
Total Members Voted: 0
Author Topic: mirror - what is wrong  (Read 3260 times)
Offline trafalgar
« on: July 07, 2010, 05:54:58 pm »
I saw "ray_bounces" tutorial  but I don Know in my preview image there is not imagen of "backplate"
only floor and walls
what can I do
thank you
Offline David
Re: mirror - what is wrong
« Reply #1 on: July 08, 2010, 02:15:19 am »
Use an Hdri environment of a river scene if you can find one?
Convert that backplate image to an Hdri if not?
put in a plane behind the mirror and map the backplate image to it as a decal?
i have not tried the last one but i'm pretty sure it would work
normally the best way to get an image with a good reflection is to use an Hdri and backplate from the same location
  • Guest
« Reply #2 on: July 08, 2010, 12:16:19 pm »
Correct. You can't convert a jpeg to an actual HDRI. jpeg is 8 bit, HDRI is 32 bit. All you will get is reflection of the environment, but not lighting information.
Offline trafalgar
Thanks - mirror again
« Reply #3 on: July 09, 2010, 09:52:37 am »
I have used keyshot's enviroment & backplate (by defect)
but i don't understan why my background don't arrive to edge
a lot of thank you
  • Guest
« Reply #4 on: July 10, 2010, 07:00:13 am »
Got to Preferences, and check "Adjust Realtime Window to Backplate". Now when you drop in a backplate, it will automatically adjust the realtime window. Or you match the aspect ratio of the realtime window manually to the back plate in the "realtime" tab.
Offline trafalgar
Re: mirror - ok!
« Reply #5 on: July 12, 2010, 06:55:38 pm »
ALL IT PERFECT!!!
Thank you so much for the help!
