Normal maps
Started by number12, April 09, 2013, 09:20:12 AM
number12
Hi Guys, just wondering what you'd recommend to use for generating normal maps to use in Keyshot? Thanks.
Most of the time you don't need a normal map. Simply apply the actual image, and KeyShot does the conversion behind the scenes.
As far as normal mapping tools go, there is a plugin for Photoshop, and dedicated texture creation application like filter forge and crazy bump.
number12
Thank you Thomas, appreciate your answer.
I was really unsure as to which method was best to use if you do need a normal map (i.e. crazybumb/Photoshop filter etc) which would give the best results?
I've been very pleased with normals (and other stuff) created in Filter Forge.  Great app!
number12
Thanks. Well look at that.
