Exhaust texture ??
Started by francq, May 01, 2013, 05:08:28 AM
francq
Hello everyone!
I'm french designer. :D
I'd like to know if it's possible to have this type of rendering in KeyShot ...
I am looking for a long time this texture. :-\
Someone has a solution?
thank you!!
I run into this many times.  I do multiple passes, each with a different overall texture/material, then composite the layers in Photoshop with selective erasure, using a very soft brush and little opacity.  It's likely impossible to get the variegated finish directly in KS.
francq
Thank you for your respond!
It's a very good idea ;D
Cliffl
You could have a go with this material I created, might need some tweaking but it gives you a starting point  :)
justindustrial
Why not lock your camera, save to a new scene file, then swap out the environment for something very colourful and change the exhaust to a chrome material to reflect the environment. Render, then composite into your full scene
